I’ve been using an old version of raidrive forever and it worked some times but recently it was giving me alot of issues so i looked on the forums and saw a beta update with some fixes for mega however when trying to use it all i get is this
normally on older versions i would load mega on my browser then right after the page loads load it on raidrive and this normally works 9/10 times but on the new version i only get error 103
any help would be great also small suggestion if you’re going to add a “retry” option you should add a check box next to it to automatically retry. retrying manually every 15-30 min just to see it fail is annoying and if i could just automate the retry on my server this issue wouldent be as bad. will keep trying before reverting to an old version and trying till it works.
this is whats making it crash
2021-03-18 00:28:03.262 [INFO] CONTROLLER: MEGA : Remote Drive Make Success
2021-03-18 00:28:04.533 [INFO] Mega API : MEGA : Account Version 1
2021-03-18 00:28:08.422 [ERROR] Mega API : MEGA : Response Exception : 0/4 : {“WinErrorCode”:1237,“NotifyErrorCode”:214,“RaiException”:“HttpPostJson Fail”,“InnerException”:“Unexpected character encountered while parsing value: \u001f. Path ‘’, line 0, position 0.”}
2021-03-18 00:28:14.589 [ERROR] Mega API : MEGA : Response Exception : 1/4 : {“WinErrorCode”:1237,“NotifyErrorCode”:214,“RaiException”:“HttpPostJson Fail”,“InnerException”:“Unexpected character encountered while parsing value: \u001f. Path ‘’, line 0, position 0.”}
2021-03-18 00:28:22.760 [ERROR] Mega API : MEGA : Response Exception : 2/4 : {“WinErrorCode”:1237,“NotifyErrorCode”:214,“RaiException”:“HttpPostJson Fail”,“InnerException”:“Unexpected character encountered while parsing value: \u001f. Path ‘’, line 0, position 0.”}
2021-03-18 00:28:35.090 [ERROR] Mega API : MEGA : GetNodes Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:214,“RaiException”:“HttpPostJson Fail”,“InnerException”:“Unexpected character encountered while parsing value: \u001f. Path ‘’, line 0, position 0.”}
2021-03-18 00:28:35.090 [ERROR] Mega (MEGA) : Auth Exception : {“WinErrorCode”:5,“NotifyErrorCode”:103,“RaiException”:“Can not get the list of files. Please try again in a few minutes.”}
2021-03-18 00:28:35.090 [ERROR] CONTROLLER: MEGA : Remote Drive Auth Failed 1 : 1/1 : {“WinErrorCode”:5,“NotifyErrorCode”:103,“RaiException”:“Can not get the list of files. Please try again in a few minutes.”}
2021-03-18 00:28:35.090 [INFO] Mega (MEGA) : Drive Stop
2021-03-18 00:28:35.090 [INFO] Mega (MEGA) : Drive Stopped
2021-03-18 00:28:35.091 [INFO] Mega (MEGA) : Drive Closed
2021-03-18 00:28:35.091 [ERROR] CONTROLLER: MEGA : Finally Remote Drive Auth Failed : {“WinErrorCode”:5,“NotifyErrorCode”:103,“RaiException”:“Can not get the list of files. Please try again in a few minutes.”}
2021-03-18 00:28:35.091 [ERROR] CONTROLLER: MEGA : Connect Finally Failed : {“WinErrorCode”:5,“NotifyErrorCode”:103,“RaiException”:“Can not get the list of files. Please try again in a few minutes.”}
ive been looking over all the mega posts looking for any kinda fix sadly nothing works. kinda sucks ive been paying for mega pro and its been more headaches then i wish to admit. great software when it works.
Hi~ @Chris48x,
Thanks a lot for your detail report.
We’ve sent the test version to you by email.
@Chris48x,
Thanks for your testing report, we think I found a clue to the solution.
We will prepare the new patch ASAP and then let you know.
hi ive tested the new build i was sent and now the error is gone but it seems like it hangs on connecting forever. ive waited over 6 hours now and nothing has updated.
used revo uninstaller to remove everything then tried the beta build again. still with no luck.
its still using resorces just never connecting
just wanna update this so i don’t leave a post with no answer
i got a beta build that worked for mounting and i will be testing. so look out for a nighty build if you have the same issue.
thanks for the support. @RaiDrive
