All the advanced options of the Drive Config are shown grey and can’t be enabled.
I want to turn on the bandwith limit.
This occurs in all my drives.
Disconnect your drive first, after that go back into settings to see if all options are available.
That’s what I needed, thank you so much.
I have another question, the education edition is limited to 2mb/s?, I have two friends that don’t have that limitation, and they use the professional edition.
Hi~ @Antonio36996 ,
RaiDrive doesn’t limit the speed on all plans. Speed may vary depending on your internet environment.
