Hi Team,
I just upgraded raiddrive to version 2026.6.25. I’m on Windows Server 2022 Datacenter 21H2
I’m getting read errors saying ‘Access is denied’ on my files. To be clear this is workflow that worked now with raiddrive for 4-5 years. I’ve upgraded the most recent version and now this issue is occurring.
I’m connecting to an azure container. I read in about 600 csv files. Randomly, the workflow now gets access denied errors on files. If I go to the file and open it from windows explorer via raiddrive it works.
Hi, @Shane_Dolley
Could you please install the Night build version below and test again?
If the problem persists, please compress the log folder below and send it to support@raidrive.com.
- C:\ProgramData\OpenBoxLab\RaiDrive Mount\log
Please send the logs or let us know the results.
Any known issue with mounting to WebDAV drives since your latest update was released? including the nightly.
I have a WebDAV connection to FileJump that has worked fairly solid this last 5 or 6 weeks and have a script which runs robocopy to keep quite a lot of files/folders consistant.
It’s not the quickest but generally works fine, but then on around the 31st I have struggled to get a sucessful robocopy to run, and strangly tonight, its working but seems to have decided to start uploading everything again, despite already been present at the remote site.
Hi, @Adam_Clarke
Could you please test again the new Night build version below?
