A public key corresponding to the supplied private key was not accepted
From some time I cannot connect to SFTP server. I didn’t change any configuration and the provided private key didn’t change. The same key works well in PuTTY and WinSCP.
I’m using RaiDrive version 2022.6.56
Thanks
Hi~ @Piotr_Marcinczyk ,
We made a new patch that fixed the issue you mentioned.
It would be of great help if you update it, check it, and let us know the result.
Hi @RaiDrive,
Sorry for the delay. The patched version works correctly.
Thanks for the help
