Version 2022.6.56 problem with sftp private key
The latest version no longer support my private key to connect to my sftp. Reverting to version 36 fixed the problem.
Hi~ @woodspire ,
To check exactly the issue you mentioned, you need the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) and drive setting screen when the issue occurs in 2022.6.56.
If you send us two pieces of information by e-mail(support@raidrive.com), we will get back to you after checking.
Hi~ @woodspire ,
This issue appears to be caused by the latest SFTP engine.
The latest RaiDrive’s SFTP engine is supposed to use the “server-sig-algs” extension, but it doesn’t appear to be supported or compatible with the server.
If you know the server OS name and version, and the SSH product name and version, please let us know.
Connect with SSH and check with the following command.
  • ssh -V
  • uname -a
Please use the old version until the new version is released.
ssh -V: OpenSSH_9.0p1 Debian-1+b1, OpenSSL 3.0.5 5 Jul 2022
uname -a: Linux beelink 5.17.4-woodspire-amd64 #1 SMP PREEMPT Thu Apr 21 02:22:46 EDT 2022 x86_64 GNU/Linux
Custom compiled kernel based on debian.
Hi~ @woodspire ,
We made a new patch that fixed the issue you mentioned.
It would be of great help if you update it, check it, and let us know the result.
Problem fixed. Thanks
