Unmounting an ISO file
i recently purchased the Local drive feature to Mount ISO files, with success the file was mounted but now windows will not allow me to eject the files. Any ideas?
Hi~ @devandev,
Have you checked whether the issue also occurs in the latest version, 2020.11.38? If you haven’t checked, check if the issue occurs after updating, and if the issue continues, send a log file(C:\ProgramData\OpenBoxLab Inc\RaiDrive\log) via e-mail(support@raidrive.com).
