Hi.
Why RaiDrive remove thumbnails cache when i close explorer folder ? this is extreme slow when all thumbnails is download.
Hi.
Hi~ @Robert_Krysztofiak ,
Thumbs.db generated by Windows does not work properly.
Even if we keep the thumbs.db file, File Explorer will download everything fresh when you reconnect the drive.
Therefore, RaiDrive does not maintain the Thumbs.db file.
Then why google drive works correct ? and only RaiDrive has problem ?
