Syncing to google drive, at some point raidrive gets stuck
As title says, been using free option for a while to access my 2TB drive. At some point the streaming from the drive gets stuck (if i try to access 30+ gb files). First i thought its because i dont have a subscription, but the same happens even with the professional one.
The only solution is to disconnect and reconnect to the drive to resume access.
it can also happen if i try to copy large amount of data to\from the drive. It copies on 80MB/s and suddenly drops to 0.
Any help on the matter would be much appreciated.
Thanks!!
Hi~ @Nathan_River ,
We apologize for any inconvenience.
Usually this is caused by Google’s Download or Upload restrictions.
Google limits the number of downloads/uploads/requests to a certain amount every hour or every day.
When this problem occurs, you can use it again after an hour or a few hours.
This is a Google limitation, and RaiDrive handles it without any restrictions on standard or professional.
It could also be an internal error in RaiDrive.
If you send us the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) by e-mail(support@raidrive.com), we will take a look and tell you again.
