Raidrive’s proxy settings spontaneous changed
Every time restart My pc, Raidrive’s proxy settings will automatically switch from Http to None.
I tried config RaiDrive.Service to Delayed start, but no work.
Hi~ @innocuously_operandi ,
We are trying to confirm the issue you mentioned.
What version is causing the issues?
the latest one. 2021.10.9 @RaiDrive
Does this issue when using a local proxy?
If you are not using a local proxy but are experiencing issues, please e-mail(support@raidrive.com) the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log).
We will tell you again after analysis.
Looking at the log you sent, it seems that you are using a proxy for localhost.
Proxy on localhost is not supported.
ok, Im going to try 127.0.0.1,and see if it work propertly @RaiDrive
hi
not work with setting as 127.0.0.1
and proxy still turn to none
I’ve sent you the new logs. @RaiDrive
Proxy on the same computer is not supported.
