RaiDrive is not Reviving
Something happened ad RaiDrive no longer revives. I click on the button to revive and it opens the dialog asking to press OK. Then, after pressed OK a Windows Dialog from UAC opens and I click YES. I can see the cursor spinning for a second (like if some task is being performed) but then nothing happens. The RaiDrive windows never changes and it never comes alive.
I’ve tried uninstalling and reinstalling (latest version) a couple of times. I’ve also tried cleaning up all traces of the application in the file system and registry before reinstalling for the third time and still no luck.
Hi~ @Chuanjin_Gao ,
We’re trying to confirm the issue you’re talking about.
A log file is required to check the issue
Please send the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) by e-mail(support@raidrive.com) and We will tell you again after checking.
