RaiDrive in 2 PC
i need to use raidrive on 2 pc. I have a purchased license, is it possible to use it with a license on two PCs? or do I need to buy another? the two pcs are on the same network.
Hi~ @Emanuel_Edward_Neatu ,
It can be used on any PC, but not at the same time.
When you have one license, if you log in on one PC and then log in on another PC, you will be logged out of the PC you were logged into first.
If you wish to use them simultaneously, you must subscribe to additional licenses for simultaneous use.
