# RaiDrive does not remember settings
**URL:** <https://with.raidrive.com/t/raidrive-does-not-remember-settings/1673>\
**Category:** General\
**Tags:** drive\
**Created:** [March 19, 2020, 4:26pm UTC](https://with.raidrive.com/t/raidrive-does-not-remember-settings/1673 "2020-03-19T16:26:30Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Mark\_Kaiser](https://with.raidrive.com/letter_avatar_proxy/v4/letter/m/58f4c7/32.png) [@Mark\_Kaiser](https://with.raidrive.com/u/Mark_Kaiser)\
**Post date:** [March 19, 2020, 4:26pm UTC](https://with.raidrive.com/t/raidrive-does-not-remember-settings/1673/1 "2020-03-19T16:26:30Z")
</div>
Hi, I am testing RaiDrive 2020.2.2 but it does not remember any settings. I am using the free version.
I am trying to map a Nextcloud folder to a drive. I have tried via the WebDAV option an via the Nextcloud option: both are not remembered upon reboot. The initial connection goes fine, seems pretty fast even. But as soon as I reboot the connection I made is gone from RaiDrive and does not show up in Windows. I even had it dissapear from RaiDrive, but the driveletter was still visible in Windows (not working though) after a suspend of my laptop…
Is this a known bug? Of even: is it possible that this is not remembered in the free version?
**Author:** ![RaiDrive](https://with.raidrive.com/user_avatar/with.raidrive.com/raidrive/32/1778_2.png) [@RaiDrive](https://with.raidrive.com/u/RaiDrive)\
**Post date:** [March 20, 2020, 2:01am UTC](https://with.raidrive.com/t/raidrive-does-not-remember-settings/1673/2 "2020-03-20T02:01:20Z")
</div>
Hi~ @Mark_Kaiser,
Thanks a lot for your report. It was a bug and fixed in a new patch.
You can download in the topic [Version 2020.2.2 patch (2020.2.12)](https://with.raidrive.com/t/version-2020-2-2-patch-2020-2-12/1415).
> [@\[SOLVED\] Upgrade 2020.2.2 : Nextcloud connexion KO](https://with.raidrive.com/t/solved-upgrade-2020-2-2-nextcloud-connexion-ko/1408):
> Hi, During the upgrade raidrive-2019-12-22 ==\> raidrive-2020.2.2, have i an technical issue, but no log founded about that :(. Except that, installation seems OK. But, when i launch raidrive, it’s empty. No configuration confused (6 drives, connected before upgrade). When i want to reconfigure my nextcloud connexion, raidrive crash when he tried to connect to the nextcloud server. Connected drives are disconnected, raidrive windows disappear and all configuration deleted cry Again, no int…
