Quick Copy enabled works as normal copy in Dropbox personal
Hello
if i enable Quick Copy in dropbox personal, it continues working as normal copy.
i have an suscription to Raidrive Education
Could you please fix it?
Hi, @Dierty_Edu
Selecting the Quick Copy option allows you to upload up to four files simultaneously when copying files from your local disk to a remote drive via Windows Explorer.
Therefore, if you are uploading a single file, the upload speed will be the same.
Using Quick Copy for uploads is helpful when disk space is an issue because the file is very large and does not need to be cached, even when uploading a single file.
Copying within the same remote drive is very fast.
Without the Quick Copy option, the process is very slow because the upload is performed while the download is in progress.
To reproduce the issue, please explain the procedure in more detail and compress the log folder below, then send it to support@raidrive.com.
If an error occurs when compressing the log folder, or if the service.log file is missing from the compressed result, please copy the log folder first and then compress the copied folder.
If you cannot find the C:\ProgramData folder, please try pasting the entire path above into the address bar of File Explorer.
