Hi, I configured OneDrive network drive and at the first glance it works perfectly and the drive has the path Z:.
Unfortunatelly the softaware I wanted to use it for sees this path as \RaiDrive-username_somewhere
which is different on different machines.
It’s vitally important for me to have identical paths for different computers. I can’t find where to control this this naming. Is there any solution?
Hi @Stepan_Andrezen,
If you access a RaiDrive-mapped drive from different machines, you need a Local Disk
addon that supports the Public
option.
This is the rule.
- Private:
\\RaiDrive-<username>\<volume label>
- Public:
\\<machine name>\<volume label>
