Installing RaiDrive_2022.6.45_x64 service does not start
Good morning, I have on several computers no connection to drives anymore with version 2022-2-30.
So I removed it and want to install RaiDrive_2022.6.45_x64.
But during install it seems to stuck at “starting service”, it takes minutes and nothing happens.
What to do?
Thanks!
Hi~ @systeembeheer,
Could you send log files to support@raidrive.com?
I’ve removed the version, installed version 22-6-36 and then 22-6-45 and now it works.
But… I cannot click “add” button and cannot click “register” button…
I can click settings
I’ve send you now also the log files
@systeembeheer,
Thanks a lot for your log files.
Probably, RaiDrive API server may has some kind of performance issue for a while.
We adjusted parameters for this issue and keep monitoring.
Could you let us know how about now?
Problem not solved. Still … I cannot click “add” button and cannot click “register” button…
I can click settings.
Several people cannot work now so major problem!
service log:
2022-08-10 06:39:19.160 [INFO] CS : CLIENT CONNECTED : 4 : 1/10
2022-08-10 06:39:23.302 [ERROR] Get Standard License Exception : {“WinErrorCode”:12,“NotifyErrorCode”:37,“RaiException”:"{“Where”:0,“ErrorType”:3,“Url”:“https://api.raidrive.com/guest/subscription",“Message”:"403 Forbidden”}"}
2022-08-10 06:39:23.302 [ERROR] DRIVEMAN : Client Register : Get License Error : {“WinErrorCode”:12,“NotifyErrorCode”:37,“RaiException”:"{“Where”:0,“ErrorType”:3,“Url”:“https://api.raidrive.com/guest/subscription",“Message”:"403 Forbidden”}"}
May I ask two question?
  1. Do you use a proxy server?
  2. Could you let us know whare your are? (country)
No we don’t use proxy. We are based in the Netherlands. Several computers have connection, others don’t! And no idea why not.
RaiDrive starts but there are no connections anymore.
Also the Add and Account buttons are greyed out. Only I can click Settings.
Please, what to do now?
installed latest version 2022.6.49 but still same problem; service log:
2022-08-12 07:16:42.893 [INFO] == RaiDrive Service Starting : Version : 2022.6.49.0
2022-08-12 07:16:42.898 [INFO] PROGRAM START : START MAIN PROCES
2022-08-12 07:16:42.899 [INFO] SYSTEMINFO : OS : Windows 7 Professional (Microsoft Windows NT 6.1.7601 Service Pack 1) : CPU : X64:X64 : Is64bit : True : IsServer : False : IsWindows7 : True
2022-08-12 07:16:42.899 [INFO] SYSTEMINFO : Language : Nederlands (Nederland)
2022-08-12 07:16:42.899 [INFO] PRODUCT NAME : RaiDrive : DATA PATH : C:\ProgramData\OpenBoxLab\RaiDrive
2022-08-12 07:16:42.904 [INFO] MAIN : START SERVICE
2022-08-12 07:16:42.924 [INFO] MAIN : START
2022-08-12 07:16:42.936 [INFO] MAIN : FILE SYSTEM DRIVER INIT
2022-08-12 07:16:42.936 [INFO] MAIN : FILE SYSTEM DRIVER Version : 6.1.184.118
2022-08-12 07:16:42.996 [INFO] DRIVEMAN : CACHE FOLDER INIT : C:\ProgramData\OpenBoxLab\RaiDrive\Cache
2022-08-12 07:16:42.999 [INFO] SERVICE : START DONE
2022-08-12 07:16:43.001 [INFO] MAIN : MAIN PROCESS THREAD START
2022-08-12 07:16:43.429 [INFO] DRIVEMAN : MAIN READY : [DRIVES:0]
2022-08-12 07:16:43.429 [INFO] MAIN : START : READY
2022-08-12 07:16:50.150 [INFO] CS : CLIENT CONNECTED : 1 : 1/10
2022-08-12 07:16:52.545 [INFO] DRIVEMAN : Client Register : FileSystem Install Check Success
2022-08-12 07:17:13.755 [ERROR] Get Standard License Exception : {"WinErrorCode":1237,"NotifyErrorCode":37,"RaiException":"{\"Where\":0,\"ErrorType\":0,\"Url\":\"https://api.raidrive.com/guest/subscription\",\"Message\":\"A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.\"}"}
2022-08-12 07:17:13.755 [ERROR] DRIVEMAN : Client Register : Get License Error : {"WinErrorCode":1237,"NotifyErrorCode":37,"RaiException":"{\"Where\":0,\"ErrorType\":0,\"Url\":\"https://api.raidrive.com/guest/subscription\",\"Message\":\"A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.\"}"}
center log:
2022-08-12 07:16:49.446 +02:00 [INF] == RaiDrive Center Starting : Version : 2022.6.49.0 ==
2022-08-12 07:16:49.459 +02:00 [INF] Microsoft Windows NT 6.1.7601 Service Pack 1 64 6.1.7601
In China, Netherlands, Australia, or elsewhere, occasionally RaiDrive servers’ IP is not resolved or rejected.
Could you let us know the resulting screenshot of the following command in a command prompt?
nslookup api.raidrive.com
computer not working:
C:\Users\stagiaire>nslookup api.raidrive.com
DNS request timed out.
    timeout was 2 seconds.
Server:  UnKnown
Address:  192.168.2.10
*** Time-out in de aanvraag aan UnKnown
C:\Users\stagiaire>
computer working:
C:\Windows\System32>nslookup api.raidrive.com
Server:  mywebui.net
Address:  192.168.1.1
Non-authoritative answer:
Addresses:  52.35.203.227
          52.27.108.201
Aliases:  api.raidrive.com
so several computers cannot lookup api.raidrive.com; But what can I do about it?
good morning, please respond it takes too much time now
Additional info, when the same computer is on another network (e.g. the person is working from home) raidrive has no problems.
So it looks like its a local network problem but nothing has changed.
I’ve found the solution. For some reason several computers had the wrong primary DNS server set up in network settings. This due to router problem. Changed that and now all is working fine.
