Installation problem
Hello, I have a problem with the installation. I have a message telling me that the drivers are not installed. Here are the logs.
I use a pro windows surface
Thank you
Davidservice.log (1.9 KB)
Hi~ @David_Blaise ,
Looking at the logs, it seems that the required drivers are not installed. If the issue is not resolved after rebooting, it is likely that you did not install the necessary drivers when installing RaiDrive. Please check by uninstalling and reinstalling RaiDrive and let us know if the problem persists.
