How do I add oracle?
I just started my free trial and I’m not sure how to connect to oracle cloud.
Thanks!
Hi~ @William_Douville ,
You can connect to Oracle Cloud from the Enterprise tap.
If you want to use write functionality, you’ll need to add the Oracle Cloud Addon from the Subscriptions menu on the homepage.
Thanks for responding, however my issue is not knowing what to put in the “access key id” and “secret access key” boxes.
You can create a secret key in the Oracle Cloud console under My profile - Customer secret keys.
I did that, put in both the access key and secret key but it still doesn’t work and won’t detect any buckets. I also put my namespace in.
If this persists, please email(support@raidrive.com) us the logfile(C:\ProgramData\OpenBoxLab\RaiDrive\log).
We’ll check it out and get back to you.
