File lock + refresh rate
Hey
I have 2 questions:
  1. there is a computer that I’m not able to check all the drives with the file lock, although I’m signed with an account with the licenses.
  2. One of the stations (another one) needs to refresh the folder to see changes, for example if the user open a new folder, he does not see it, only after refreshing he will see that it actually was created.
I’m using WebDAV without SSL, download speed from the server is 100MBps, and in other stationes it works ok.
Thanks
Amir
Hi~ @BGPC ,
We are trying to reproduce the issue you mentioned.
It would be of great help if you could provide a detailed description of the issue for accurate reproduction.
