Explorer freezes
Dear team,
mostly I use the notepad++
and when I use in them the explorer, for open new file,
the notepad freeze.
When it happens, I must wait some minutes (1-4mins), or kill raidrive,
otherwise the notepad++ not respond.
My specs:
Windows 10
RaiDrive ver: 2020.11.30
Disk mounted over sftp
Notepad++ ver: 8.1.9
Could you please take a look on this issue?
Thanks!
Hi~ @vaskolabovsky ,
We’re trying to confirm the issue you mentioned.
A log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) is required for accurate verification.
If you send the log file via e-mail(support@raidrive.com) immediately after the issue occurs, we will check it and tell you again.
I am having this same issue. RaiDrive freezes and any window that is attempting to access the file system also freezes. It used to be for several seconds, with the upgrade to 2021.12.37, it is longer. In the past, I could manually disconnect my remote mount and reconnect and everything would start working. Now, with this upgrade, I am unable to disconnect at all. I attempted to downgrade, but the installer would not let me do so.
