Not sure what I am doing here but when I try to install it sends me in a sort of loop with the .net thing. Tried originally with chocolatey but I can’t get it to work, have restarted PC as well with no luck.
Here is my log: (most of it)
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘9’. Its new value: ‘8’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘8’. Its new value: ‘7’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘7’. Its new value: ‘6’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘6’. Its new value: ‘5’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘5’. Its new value: ‘4’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘4’. Its new value: ‘3’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘3’. Its new value: ‘2’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘2’. Its new value: ‘1’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘1’. Its new value: ‘0’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘500’. Its new value: ‘400’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘500’. Its new value: ‘400’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘0’. Its new value: ‘14’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘14’. Its new value: ‘13’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘13’. Its new value: ‘12’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘12’. Its new value: ‘11’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘11’. Its new value: ‘10’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘10’. Its new value: ‘9’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘400’. Its new value: ‘1000’.
MSI (c) (6C:F0) [19:20:22:967]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘400’. Its new value: ‘1000’.
MSI (c) (6C:F0) [19:20:22:968]: MsiOpenPackageEx is returning 0
MSI (c) (6C:F0) [19:20:22:968]: MsiOpenPackage is returning 0
MSI (c) (6C:F0) [19:20:22:968]: Note: 1: 2205 2: 3: MultipleInstancesProps
MSI (c) (6C:F0) [19:20:22:968]: Note: 1: 2228 2: 3: MultipleInstancesProps 4: SELECT PropertyValue
FROM MultipleInstancesProps
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is ‘5’.
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH property. Its value is ‘C:\Users\henry\AppData\Local\Temp\RaiDrive_latest_x64.exe’.
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding AI_LOGFILELOCATION property. Its value is ‘C:\Users\henry\AppData\Local\Temp\MSI3AAD.LOG’.
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding SETUPEXEDIR property. Its value is 'C:\Users\henry\AppData\Local\Temp'.
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding EXE_CMD_LINE property. Its value is '/exenoupdates /forcecleanup /wintime 1693937221 '.
MSI (c) (6C:F0) [19:20:22:971]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is ‘APPDIR’.
MSI (c) (6C:F0) [19:20:22:981]: PROPERTY CHANGE: Adding AI_IE_Ver property. Its value is ‘11’.
MSI (c) (6C:F0) [19:20:22:981]: PROPERTY CHANGE: Adding AI_IE_MinorVer property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:22:981]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is ‘11372’.
MSI (c) (6C:F0) [19:20:22:981]: PROPERTY CHANGE: Adding AI_BOOTSTRAPPER property. Its value is ‘1’.
MSI (c) (6C:F0) [19:20:22:981]: Doing action: AI_DETECT_WINTHEME
Action start 19:20:22: AI_DETECT_WINTHEME.
MSI (c) (6C:04) [19:20:22:984]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3B3B.tmp, Entrypoint: DetectWindowsTheme
MSI (c) (6C:BC) [19:20:22:985]: Cloaking enabled.
MSI (c) (6C:BC) [19:20:22:986]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (6C:BC) [19:20:22:986]: Connected to service for CA interface.
MSI (c) (6C!98) [19:20:23:037]: PROPERTY CHANGE: Adding DarkTheme property. Its value is ‘1’.
Action ended 19:20:23: AI_DETECT_WINTHEME. Return value 1.
MSI (c) (6C:F0) [19:20:23:040]: Doing action: AI_DpiContentScale
Action start 19:20:23: AI_DpiContentScale.
MSI (c) (6C:9C) [19:20:23:042]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3B7B.tmp, Entrypoint: DpiContentScale
MSI (c) (6C!D8) [19:20:23:048]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is ‘96’.
MSI (c) (6C!D8) [19:20:23:048]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is ‘100’.
Action ended 19:20:23: AI_DpiContentScale. Return value 1.
MSI (c) (6C:F0) [19:20:23:078]: Doing action: LanguageDlg
Action start 19:20:23: LanguageDlg.
MSI (c) (6C:30) [19:20:23:079]: Note: 1: 2205 2: 3: AI_ControlConditionEx
MSI (c) (6C:30) [19:20:23:079]: Note: 1: 2228 2: 3: AI_ControlConditionEx 4: SELECT Dialog_
,Control_
,Action
,Condition
FROM AI_ControlConditionEx
MSI (c) (6C:30) [19:20:23:079]: Note: 1: 2205 2: 3: AI_EventMappingEx
MSI (c) (6C:30) [19:20:23:079]: Note: 1: 2228 2: 3: AI_EventMappingEx 4: SELECT Dialog_
,Control_
,Event
,Attribute
FROM AI_EventMappingEx
Action ended 19:20:24: LanguageDlg. Return value 1.
MSI (c) (6C:F0) [19:20:24:052]: Doing action: AI_DetectSoftware
Action start 19:20:24: AI_DetectSoftware.
MSI (c) (6C:D4) [19:20:24:055]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3F73.tmp, Entrypoint: OnDetectSoftware
MSI (c) (6C!6C) [19:20:24:067]: PROPERTY CHANGE: Adding AI_DETECTED_INTERNET_CONNECTION property. Its value is ‘1’.
Action ended 19:20:24: AI_DetectSoftware. Return value 1.
MSI (c) (6C:F0) [19:20:24:069]: Doing action: PreparePrereqDlg
Action start 19:20:24: PreparePrereqDlg.
Action ended 19:20:24: PreparePrereqDlg. Return value 1.
MSI (c) (6C:F0) [19:20:24:094]: Doing action: AI_DETECT_MODERNWIN
Action start 19:20:24: AI_DETECT_MODERNWIN.
MSI (c) (6C:20) [19:20:24:099]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FA3.tmp, Entrypoint: DetectModernWindows
Action ended 19:20:24: AI_DETECT_MODERNWIN. Return value 1.
MSI (c) (6C:F0) [19:20:24:108]: Doing action: AppSearch
Action start 19:20:24: AppSearch.
MSI (c) (6C:F0) [19:20:24:110]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (6C:F0) [19:20:24:110]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Caphyon\Advanced Installer\LZMA{E029C1F7-1A1F-48E1-959F-DC657DCDAD94}\2023.9.0 3: 2
MSI (c) (6C:F0) [19:20:24:111]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Caphyon\Advanced Installer\LZMA{E029C1F7-1A1F-48E1-959F-DC657DCDAD94}\2023.9.0 3: 2
Action ended 19:20:24: AppSearch. Return value 1.
MSI (c) (6C:F0) [19:20:24:111]: Doing action: AI_AppSearchEx
Action start 19:20:24: AI_AppSearchEx.
MSI (c) (6C:B4) [19:20:24:114]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FB4.tmp, Entrypoint: DoAppSearchEx
MSI (c) (6C!C8) [19:20:24:125]: PROPERTY CHANGE: Adding PreReqSearch_C4FE6FD5B7C4D07B3A313EAiVerMin property. Its value is ‘14.30.30704’.
MSI (c) (6C!C8) [19:20:24:125]: PROPERTY CHANGE: Adding PreReqSearch_C4FE6FD5B7C4D07B3A313EAiVerFound property. Its value is ‘14.36.32532’.
MSI (c) (6C!C8) [19:20:24:125]: PROPERTY CHANGE: Adding PreReqSearch_C4FE6FD5B7C4D07B3A313E property. Its value is ‘14.36.32532’.
MSI (c) (6C!C8) [19:20:24:127]: PROPERTY CHANGE: Adding PreReqSearch_FAC9C433D3044829E6669AAiVerMin property. Its value is ‘6.0.16’.
MSI (c) (6C!C8) [19:20:24:127]: PROPERTY CHANGE: Adding PreReqSearch_FAC9C433D3044829E6669AAiVerFound property. Its value is ‘6.0.21’.
MSI (c) (6C!C8) [19:20:24:127]: PROPERTY CHANGE: Adding PreReqSearch_FAC9C433D3044829E6669A property. Its value is ‘6.0.21’.
MSI (c) (6C!C8) [19:20:24:130]: PROPERTY CHANGE: Adding PreReqSearch_AF4EF7137AE24E488A4E_1AiVerMin property. Its value is ‘110.0.1587.63’.
MSI (c) (6C!C8) [19:20:24:132]: PROPERTY CHANGE: Adding PreReqSearch_1AiVerMin property. Its value is ‘110.0.1587.63’.
MSI (c) (6C!C8) [19:20:24:132]: PROPERTY CHANGE: Adding PreReqSearch_1AiVerFound property. Its value is ‘116.0.1938.69’.
MSI (c) (6C!C8) [19:20:24:132]: PROPERTY CHANGE: Adding PreReqSearch_1 property. Its value is ‘116.0.1938.69’.
MSI (c) (6C!C8) [19:20:24:143]: PROPERTY CHANGE: Adding AI_PrereqsFulfilled property. Its value is ‘1’.
Action ended 19:20:24: AI_AppSearchEx. Return value 1.
MSI (c) (6C:F0) [19:20:24:145]: Doing action: LaunchConditions
Action start 19:20:24: LaunchConditions.
Action ended 19:20:24: LaunchConditions. Return value 1.
MSI (c) (6C:F0) [19:20:24:147]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (6C:F0) [19:20:24:147]: Note: 1: 2205 2: 3: MultipleInstances
MSI (c) (6C:F0) [19:20:24:147]: Note: 1: 2228 2: 3: MultipleInstances 4: SELECT InstKey
,InstancesId
,Order
MSI (c) (6C:F0) [19:20:24:147]: Note: 1: 2205 2: 3: MultipleInstancesProps
MSI (c) (6C:F0) [19:20:24:147]: Note: 1: 2228 2: 3: MultipleInstancesProps 4: SELECT Instance
,PropertyName
,PropertyValue
MSI (c) (6C:F0) [19:20:24:147]: PROPERTY CHANGE: Deleting AI_BOOTSTRAPPER property. Its current value is ‘1’.
MSI (c) (6C:F0) [19:20:24:148]: Doing action: AI_SET_INSTALL
Action start 19:20:24: AI_SET_INSTALL.
MSI (c) (6C:F0) [19:20:24:149]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is ‘1’.
Action ended 19:20:24: AI_SET_INSTALL. Return value 1.
MSI (c) (6C:F0) [19:20:24:149]: Doing action: AI_DETECT_MODERNWIN
MSI (c) (6C:38) [19:20:24:152]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FD4.tmp, Entrypoint: DetectModernWindows
MSI (c) (6C:F0) [19:20:24:159]: Doing action: AI_DETECT_WINTHEME
Action start 19:20:24: AI_DETECT_WINTHEME.
MSI (c) (6C:78) [19:20:24:162]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FE5.tmp, Entrypoint: DetectWindowsTheme
Action ended 19:20:24: AI_DETECT_WINTHEME. Return value 1.
MSI (c) (6C:F0) [19:20:24:169]: Doing action: AI_EnableDebugLog
Action start 19:20:24: AI_EnableDebugLog.
MSI (c) (6C:30) [19:20:24:172]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FE6.tmp, Entrypoint: EnableDebugLog
AI_EnableDebugLog: Log disabled
Action ended 19:20:24: AI_EnableDebugLog. Return value 1.
MSI (c) (6C:F0) [19:20:24:180]: Doing action: AI_DpiContentScale
Action start 19:20:24: AI_DpiContentScale.
MSI (c) (6C:F0) [19:20:24:183]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI3FF6.tmp, Entrypoint: DpiContentScale
Action ended 19:20:24: AI_DpiContentScale. Return value 1.
MSI (c) (6C:F0) [19:20:24:213]: Doing action: AI_ResolveKnownFolders
Action start 19:20:24: AI_ResolveKnownFolders.
MSI (c) (6C:04) [19:20:24:216]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4017.tmp, Entrypoint: AI_ResolveKnownFolders
MSI (c) (6C!BC) [19:20:24:226]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\henry\Saved Games'.
MSI (c) (6C!BC) [19:20:24:227]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\henry\AppData\Roaming\Microsoft\Windows\Libraries'.
MSI (c) (6C!BC) [19:20:24:228]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents'.
MSI (c) (6C!BC) [19:20:24:229]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public'.
MSI (c) (6C!BC) [19:20:24:230]: PROPERTY CHANGE: Adding UserProfileFolder property. Its value is 'C:\Users\henry'.
Action ended 19:20:24: AI_ResolveKnownFolders. Return value 1.
MSI (c) (6C:F0) [19:20:24:232]: Doing action: PrepareDlg
Action start 19:20:24: PrepareDlg.
Action ended 19:20:24: PrepareDlg. Return value 1.
MSI (c) (6C:F0) [19:20:24:267]: Doing action: AI_BACKUP_AI_SETUPEXEPATH
Action start 19:20:24: AI_BACKUP_AI_SETUPEXEPATH.
MSI (c) (6C:F0) [19:20:24:270]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH_ORIGINAL property. Its value is ‘C:\Users\henry\AppData\Local\Temp\RaiDrive_latest_x64.exe’.
Action ended 19:20:24: AI_BACKUP_AI_SETUPEXEPATH. Return value 1.
MSI (c) (6C:F0) [19:20:24:270]: Doing action: AppSearch
MSI (c) (6C:F0) [19:20:24:273]: Doing action: AI_DetectSoftware
MSI (c) (6C:C0) [19:20:24:276]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4056.tmp, Entrypoint: OnDetectSoftware
MSI (c) (6C:F0) [19:20:24:287]: Doing action: AI_AppSearchEx
MSI (c) (6C:00) [19:20:24:290]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4067.tmp, Entrypoint: DoAppSearchEx
MSI (c) (6C:F0) [19:20:24:320]: Doing action: AI_RESTORE_AI_SETUPEXEPATH
Action start 19:20:24: AI_RESTORE_AI_SETUPEXEPATH.
Action ended 19:20:24: AI_RESTORE_AI_SETUPEXEPATH. Return value 1.
MSI (c) (6C:F0) [19:20:24:321]: Doing action: AI_PRESERVE_INSTALL_TYPE
Action start 19:20:24: AI_PRESERVE_INSTALL_TYPE.
MSI (c) (6C:C8) [19:20:24:323]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4087.tmp, Entrypoint: PreserveInstallType
Action ended 19:20:24: AI_PRESERVE_INSTALL_TYPE. Return value 1.
MSI (c) (6C:F0) [19:20:24:331]: Doing action: FindRelatedProducts
Action start 19:20:24: FindRelatedProducts.
Action ended 19:20:24: FindRelatedProducts. Return value 1.
MSI (c) (6C:F0) [19:20:24:333]: Doing action: LaunchConditions
MSI (c) (6C:F0) [19:20:24:335]: Doing action: AI_RESTORE_LOCATION
Action start 19:20:24: AI_RESTORE_LOCATION.
MSI (c) (6C:A4) [19:20:24:337]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4098.tmp, Entrypoint: RestoreLocation
Action ended 19:20:24: AI_RESTORE_LOCATION. Return value 1.
MSI (c) (6C:F0) [19:20:24:352]: Doing action: SET_APPDIR
Action start 19:20:24: SET_APPDIR.
MSI (c) (6C:F0) [19:20:24:352]: PROPERTY CHANGE: Adding APPDIR property. Its value is ‘C:\Program Files\OpenBoxLab\RaiDrive’.
Action ended 19:20:24: SET_APPDIR. Return value 1.
MSI (c) (6C:F0) [19:20:24:352]: Doing action: SET_SHORTCUTDIR
Action start 19:20:24: SET_SHORTCUTDIR.
MSI (c) (6C:F0) [19:20:24:353]: PROPERTY CHANGE: Adding SHORTCUTDIR property. Its value is ‘C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RaiDrive’.
Action ended 19:20:24: SET_SHORTCUTDIR. Return value 1.
MSI (c) (6C:F0) [19:20:24:354]: Doing action: CostInitialize
Action start 19:20:24: CostInitialize.
MSI (c) (6C:F0) [19:20:24:354]: Machine policy value ‘MaxPatchCacheSize’ is 10
MSI (c) (6C:F0) [19:20:24:356]: Note: 1: 1336 2: 2 3: G:\
MSI (c) (6C:F0) [19:20:24:356]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:'.
MSI (c) (6C:F0) [19:20:24:356]: PROPERTY CHANGE: Adding CostingComplete property. Its value is ‘0’.
Action ended 19:20:24: CostInitialize. Return value 1.
MSI (c) (6C:F0) [19:20:24:357]: Doing action: FileCost
Action start 19:20:24: FileCost.
MSI (c) (6C:F0) [19:20:24:358]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (6C:F0) [19:20:24:358]: Note: 1: 2205 2: 3: Class
MSI (c) (6C:F0) [19:20:24:358]: Note: 1: 2205 2: 3: Extension
MSI (c) (6C:F0) [19:20:24:358]: Note: 1: 2205 2: 3: TypeLib
Action ended 19:20:24: FileCost. Return value 1.
MSI (c) (6C:F0) [19:20:24:359]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (6C:F0) [19:20:24:359]: Doing action: CostFinalize
Action start 19:20:24: CostFinalize.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is ‘0’.
MSI (c) (6C:F0) [19:20:24:360]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (6C:F0) [19:20:24:360]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:'.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Modifying SHORTCUTDIR property. Its current value is ‘C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RaiDrive’. Its new value: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RaiDrive'.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Modifying APPDIR property. Its current value is ‘C:\Program Files\OpenBoxLab\RaiDrive’. Its new value: 'C:\Program Files\OpenBoxLab\RaiDrive'.
MSI (c) (6C:F0) [19:20:24:360]: PROPERTY CHANGE: Adding driver_Dir property. Its value is 'C:\Program Files\OpenBoxLab\RaiDrive\driver'.
MSI (c) (6C:F0) [19:20:24:360]: Target path resolution complete. Dumping Directory table…
MSI (c) (6C:F0) [19:20:24:360]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (6C:F0) [19:20:24:360]: Dir (target): Key: TARGETDIR , Object: C:
MSI (c) (6C:F0) [19:20:24:360]: Dir (target): Key: WindowsFolder , Object: C:\Windows
MSI (c) (6C:F0) [19:20:24:360]: Dir (target): Key: DesktopFolder , Object: C:\Users\Public\Desktop
MSI (c) (6C:F0) [19:20:24:360]: Dir (target): Key: SHORTCUTDIR , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RaiDrive
MSI (c) (6C:F0) [19:20:24:360]: Dir (target): Key: APPDIR , Object: C:\Program Files\OpenBoxLab\RaiDrive
MSI (c) (6C:F0) [19:20:24:361]: Dir (target): Key: driver_Dir , Object: C:\Program Files\OpenBoxLab\RaiDrive\driver
MSI (c) (6C:F0) [19:20:24:361]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (6C:F0) [19:20:24:361]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT MsiAssembly
.Attributes
, MsiAssembly
.File_Application
, MsiAssembly
.File_Manifest
, Component
.KeyPath
FROM MsiAssembly
, Component
WHERE MsiAssembly
.Component_
= Component
.Component
AND MsiAssembly
.Component_
Action ended 19:20:24: CostFinalize. Return value 1.
MSI (c) (6C:F0) [19:20:24:361]: Doing action: MigrateFeatureStates
Action start 19:20:24: MigrateFeatureStates.
Action ended 19:20:24: MigrateFeatureStates. Return value 0.
MSI (c) (6C:F0) [19:20:24:363]: Doing action: WelcomeDlg
Action start 19:20:24: WelcomeDlg.
MSI (c) (6C:D8) [19:20:26:244]: PROPERTY CHANGE: Adding IAgreeInstall property. Its value is ‘Yes’.
MSI (c) (6C:C4) [19:20:26:248]: PROPERTY CHANGE: Modifying IAgree property. Its current value is ‘No’. Its new value: ‘Yes’.
Action ended 19:20:26: WelcomeDlg. Return value 1.
MSI (c) (6C:F0) [19:20:26:676]: Doing action: InstallDlg
Action start 19:20:26: InstallDlg.
Action ended 19:20:27: InstallDlg. Return value 1.
MSI (c) (6C:F0) [19:20:27:193]: Doing action: InstallValidate
Action start 19:20:27: InstallValidate.
MSI (c) (6C:F0) [19:20:27:193]: Feature: MainFeature; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Feature: C4FE6FD5B7C4D07B3A313E754A9A6A8; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: APPDIR; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.Service.x64.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: AI_CustomARPName; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: System; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: IoBlockLegacyFsFilters; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: CurrentControlSet; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: Control; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: SessionManager; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.Service.x64.exe; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.runtimeconfig.json; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: Ijwhost.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.ThumbnailHandler.x64.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.ShellExtension.x64.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: Microsoft; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: Windows; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: CurrentVersion; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: WebView2Loader.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: RaiDrive.exe; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: SHORTCUTDIR; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: ProductName; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: CBFS6Net.dll; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: cbfs.cab; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: AI_ExePath; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: AI_InstallLanguage; Installed: Absent; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __RaiDrive.exe65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __RaiDrive.exe66; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __System65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __IoBlockLegacyFsFilters65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __CurrentControlSet65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __Control65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __SessionManager65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __ProductName65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __AI_ExePath65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __AI_InstallLanguage65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __AI_CustomARPName65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __CurrentVersion65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __Microsoft65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Component: __Windows65; Installed: Null; Request: Local; Action: Local
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: BindImage
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: ProgId
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: PublishComponent
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: Extension
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: Font
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: Class
MSI (c) (6C:F0) [19:20:27:193]: Note: 1: 2205 2: 3: TypeLib
MSI (c) (6C:F0) [19:20:27:194]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (c) (6C:F0) [19:20:27:194]: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (6C:F0) [19:20:27:197]: Note: 1: 1402 2: HKEY_CLASSES_ROOT.0 3: 2
MSI (c) (6C:F0) [19:20:27:198]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is ‘0’. Its new value: ‘1’.
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: BindImage
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: ProgId
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: PublishComponent
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: Extension
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: Font
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: Class
MSI (c) (6C:F0) [19:20:27:199]: Note: 1: 2205 2: 3: TypeLib
MSI (c) (6C:F0) [19:20:27:199]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is ‘0’. Its new value: ‘392826352’.
MSI (c) (6C:F0) [19:20:27:199]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRequired property. Its current value is ‘0’. Its new value: ‘62787’.
MSI (c) (6C:F0) [19:20:27:199]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is ‘0’. Its new value: ‘392763565’.
MSI (c) (6C:F0) [19:20:27:199]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is ‘C:’.
Action ended 19:20:27: InstallValidate. Return value 1.
MSI (c) (6C:F0) [19:20:27:200]: Doing action: VerifyReadyDlg
Action start 19:20:27: VerifyReadyDlg.
Action ended 19:20:27: VerifyReadyDlg. Return value 1.
MSI (c) (6C:F0) [19:20:27:201]: Doing action: ProgressDlg
Action start 19:20:27: ProgressDlg.
Action ended 19:20:27: ProgressDlg. Return value 1.
MSI (c) (6C:F0) [19:20:27:229]: Note: 1: 2205 2: 3: AI_TempFile
MSI (c) (6C:F0) [19:20:27:229]: Note: 1: 2228 2: 3: AI_TempFile 4: SELECT Property
FROM AI_TempFile
MSI (c) (6C:F0) [19:20:27:229]: Note: 1: 2205 2: 3: AI_XmlLocator
MSI (c) (6C:F0) [19:20:27:229]: Note: 1: 2228 2: 3: AI_XmlLocator 4: SELECT Property
FROM AI_XmlLocator
MSI (c) (6C:F0) [19:20:27:231]: Note: 1: 2205 2: 3: IsolatedComponent
MSI (c) (6C:F0) [19:20:27:231]: Note: 1: 2228 2: 3: IsolatedComponent 4: SELECT Component_Shared
,Component_Application
FROM IsolatedComponent
MSI (c) (6C:F0) [19:20:27:231]: Doing action: AI_AppSearchEx
Action start 19:20:27: AI_AppSearchEx.
MSI (c) (6C:6C) [19:20:27:234]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI4BE3.tmp, Entrypoint: DoAppSearchEx
Action ended 19:20:27: AI_AppSearchEx. Return value 1.
MSI (c) (6C:F0) [19:20:27:259]: Doing action: AI_VerifyPrereq
Action start 19:20:27: AI_VerifyPrereq.
Action ended 19:20:27: AI_VerifyPrereq. Return value 1.
MSI (c) (6C:F0) [19:20:27:260]: PROPERTY CHANGE: Adding FASTOEM property. Its value is ‘1’.
MSI (c) (6C:F0) [19:21:51:934]: Doing action: FatalError
Action start 19:21:51: FatalError.
Action ended 19:21:53: FatalError. Return value 1.
MSI (c) (6C:F0) [19:21:53:415]: Doing action: AI_SHOW_LOG
Action start 19:21:53: AI_SHOW_LOG.
MSI (c) (6C:0C) [19:21:53:417]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI9C90.tmp, Entrypoint: LaunchLogFile
Action ended 19:21:53: AI_SHOW_LOG. Return value 1.
MSI (c) (6C:F0) [19:21:53:512]: Doing action: FatalError
Action start 19:21:53: FatalError.
MSI (c) (6C:F0) [19:21:53:513]: Doing action: AI_RollbackPrePrereq
Action start 19:21:53: AI_RollbackPrePrereq.
MSI (c) (6C:28) [19:21:53:515]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI9CEF.tmp, Entrypoint: RollbackPrePrereq
Action ended 19:21:53: AI_RollbackPrePrereq. Return value 1.
MSI (c) (6C:F0) [19:21:53:521]: Doing action: FatalError
MSI (c) (6C:F0) [19:21:53:522]: Doing action: AI_CleanPrePrereq
Action start 19:21:53: AI_CleanPrePrereq.
MSI (c) (6C:58) [19:21:53:523]: Invoking remote custom action. DLL: C:\Users\henry\AppData\Local\Temp\MSI9CFF.tmp, Entrypoint: CleanPrereq
Action ended 19:21:53: AI_CleanPrePrereq. Return value 1.
MSI (c) (6C:F0) [19:21:53:531]: Doing action: FatalError
Action ended 19:21:53: FatalError. Return value 2.
MSI (c) (6C:F0) [19:21:53:532]: Note: 1: 2205 2: 3: Environment
MSI (c) (6C:F0) [19:21:53:532]: Note: 1: 2228 2: 3: Environment 4: SELECT Environment
,Component_
FROM Environment
MSI (c) (6C:F0) [19:21:53:543]: Destroying RemoteAPI object.
MSI (c) (6C:BC) [19:21:53:544]: Custom Action Manager thread ending.
=== Verbose logging stopped: 05/09/2023 19:21:53 ===
