Error {"WinErrorCode":1237,"NotifyErrorCode":205
Error {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Folder Failed : Remote Drive Failed.”,“Filename”:"/LeTuanData/key install windows 10.txt/.tmp"
How to solve this problem?
2020-12-09 14:47:57.167 [INFO] FILESYSTEM : LeTuanDisk : Get Volume Label : LeTuanDisk
2020-12-09 14:47:57.172 [INFO] FILESYSTEM : LeTuanDisk : MountMedia Success
2020-12-09 14:47:57.177 [INFO] FILESYSTEM : LeTuanDisk : MountPoint Add Z: Success
2020-12-09 14:47:57.177 [INFO] CONTROLLER: LeTuanDisk : Mount Success
2020-12-09 14:47:57.177 [INFO] CONTROLLER: LeTuanDisk : Drive Connect Success
2020-12-09 14:48:05.504 [INFO] OneDriveBusiness (LeTuanDisk) : Check Change Thread Start
2020-12-09 14:48:20.934 [ERROR] OneDriveBusiness FILEMANAGER : Add Failed : Parent AddChild Failed : /letuandata/key install windows 10.txt
2020-12-09 14:48:20.935 [ERROR] OneDriveBusiness (LeTuanDisk) : CreateFolder Fail. : /LeTuanData/key install windows 10.txt/.tmp : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Folder Failed : Remote Drive Failed.”,“Filename”:"/LeTuanData/key install windows 10.txt/.tmp",“Processname”:"\Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe"}
2020-12-09 14:48:20.941 [ERROR] FILESYSTEM : LeTuanDisk : CreateFolder Error : \LeTuanData\key install windows 10.txt.tmp : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Folder Failed : Remote Drive Failed.”,“Filename”:"/LeTuanData/key install windows 10.txt/.tmp",“Processname”:"\Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe"} : \Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe
2020-12-09 14:48:20.956 [ERROR] FILESYSTEM : LeTuanDisk : OpenFile Error : \LeTuanData\key install windows 10.txt : The system cannot find the file specified : \Device\HarddiskVolume1\Windows\explorer.exe
2020-12-09 14:48:26.184 [ERROR] OneDriveBusiness FILEMANAGER : Add Failed : Parent AddChild Failed : /letuandata/win10 edu.txt
2020-12-09 14:48:26.185 [ERROR] OneDriveBusiness (LeTuanDisk) : CreateFolder Fail. : /LeTuanData/Win10 EDU.txt/.tmp : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Folder Failed : Remote Drive Failed.”,“Filename”:"/LeTuanData/Win10 EDU.txt/.tmp",“Processname”:"\Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe"}
2020-12-09 14:48:26.185 [ERROR] FILESYSTEM : LeTuanDisk : CreateFolder Error : \LeTuanData\Win10 EDU.txt.tmp : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Folder Failed : Remote Drive Failed.”,“Filename”:"/LeTuanData/Win10 EDU.txt/.tmp",“Processname”:"\Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe"} : \Device\HarddiskVolume1\Program Files\Google\Drive\googledrivesync.exe
2020-12-09 14:48:26.198 [ERROR] FILESYSTEM : LeTuanDisk : OpenFile Error : \LeTuanData\Win10 EDU.txt : The system cannot find the file specified : \Device\HarddiskVolume1\Windows\explorer.exe
I solved problem by uninstalled googledrive
haha
