Education License and Adverts
I am trying to test RaiDrive with the Education License. It seems to be showing advertisements in a popup from the system tray. Is this normal? If so we will not be able to use RaiDrive.
Thx
Hi~ @Peter ,
Education licenses display ads.
To remove ads, you must change your subscription to Academic or Professional Edition.
Ok, thank you.
Got to find another solution.
@Peter @RaiDrive
ads are very annoying
TRY rclone
Free forever
Thanks for the suggestion. Its for less than tech savy end users so needs to be GUI. We cant use RaiDrive because of the ads though. Ill keep looking. :slight_smile:
