Drive icon display statement
I plug in my USB drive or any external drive, the D drive will show RaiDrive icon as the drive icon.
This is the solution for the symptom you are inquiring about.
  1. Windows Search > Enter ‘regedit’ > Run ‘regedit’
  2. Go to HKEY_CURRENT_USER \ Software \ Classes \ Applications \ Explorer.exe \ Drives
  3. If you remove the error folder under the Drives folder, you can use it as a drive icon in its original state.
