Hello
when I copy (or move) files from whatever (local windows HD, or Google drive) to my Synology (using widows explorer and drag and drop)
- it works fine with the first few files
- then it gets stuck, potentially aborting windows explorer but not always
It used to work perfectly well “before”.
My windows is uptodate, so is Raidrive.
Not sure how to investigate/fix…
Regards
