Can't login after update pro
i used 8 slot in free and update pro but i can’t login in app
after i login in its alway stuck in here ,i try create second acc but still that happen .
try email for support@raidrive.com but dont reply :frowning:
help me
Hi~ @linh_linh,
According to your email, your account had been locked for 5 minutes.
Now, you may be able to sign in RaiDrive. :slightly_smiling_face:
but look like i only can login 1 pc in same time ?
If you are asking about the Professional session,
one session will be activated at the only one PC.
If you activate on two PC at the same time, you need two sessions.
I have 3 sessions but only one of it has been used, maybe I got locked ?
Hi~ @Coral,
Very sorry for your inconvenience.
We found out why this happened and fixed it now.
