Cannot connect to m365
SEEMS LIKE RAI DRIVE IS HAVING ISSUES WITH M365 TODAY???
ERROR: “Signing Key Is Invalid”.
Help!
I´m having exactly the same problem here!
I’m connected to one client’s OneDrive but can’t connect to another client’s OneDrive. Previously worked fine connecting to both. The one I can’t connect to uses 2FA, the other that connects okay does not use 2FA.
Just saw in Reuters - it appears to be a MS issue affecting thousands after system updates.
That’s not good! I hope they fix it fast.
All of our accounts use 2FA. This is most likely the issue.
I am now able to connect to the M365 accounts. It’s great that they handled this so quickly.
