Azure Blog Storage problems
HI We are connecting Rai Drive with Azure Blog Storage with a Windows 2019 server . Normally, everythings wors fine until you start working with windows explorer and the the azure storage . After some time working with the storage folders thorught the windows explorer the sustema nad storage access get (No response) and we need to reboot the computer in order to retrieve the Storage access and computer stability . Any support will be really appreciate .
Thanks
Hi~ @Oscar_Monrio ,
From what you said, We don’t understand the exact situation.
Please let us know a little more specific situation (so that it can be reproduced) by e-mail(support@raidrive.com).
It would be of great help if you send the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) when an error occurs.
HI, I am not able to see the log folder. How can I enable it?
Thanks
Hi~ @Oscar_Monrio ,
  • How to access the ProgramData folder.
After moving to Local Disk (C:), if you check Hidden items in the View menu at the top of the explorer, the ProgramData folder is displayed.
