Annoying asking for login for OneDrive
Everytime that I try to connect to OneDrive O get login prompt webpage which is very annoying ,
If I change drive setting I transfered to login page of onedrive to issue premitt access to rai drive ,
If I have multiple OneDrive in RaiDrive at least one of them annoysme for login.
Login to ONEDrive should be once and no more, kidnly solve this very ANNOYING ISSUE, or if the issue is with the Microsoft consider to agree upon a solution.
Too much login to OneDrive is not tolerated.
Thanks
Hi~ @ssskypesw,
Probably you need to un-check Connect using different credentials option.
If you check, it will ask to sign in again every time to connect.
You can see more detail information in the following link
https://docs.raidrive.com/options/connect-using-different-credentials.html#cloud-storage-sign-in
